polar position
I cannot figure out what polar position is. In my mind, it should be a distance and an angle from the origin of the base alignment, but that is not the case.
Attached are two pictures. One shows a point near a notch. The other shows a point on the side of the notch. The notch is centered nominally at 15 degrees ccw from +Z in the XZ plane. The outside circle has a radius of 5.24".
I need the angle and the depth of the notch, so I thought to use polar coordinates.
1.) Highlight the space points.
2.) Resources -> Features representation...
3.) Mode dropdown to Modify
4.) Select Cyl., R, A, and H
Note that R is vastly different from one to the other, and both are totally wrong. Same with the angle. And the Height.
The points can run.
3d constructions from the center of the base alignment to each point show the correct A2 angle of about 15.
The 2d Polar Distance characteristic shows the correct radius (using the base alignment features as datums).
Can somebody please explain this?
It looks like some kind of vectoring issue. The H value should be the same or at least close (Y axis). I would try playing with the vectors and see if you can get what you expect.
It is definitely a vector issue. Change the vector (using button shown in attachment) and then adjust the H, when the H moves in the correct direction you have the correct vector and the numbers should make sense then. If you adjust H and it moves in the wrong direction hit reset and try again. I am guessing it might be the X vector but not 100% sure.
There are two of that image. Which one?
I tried screwing with both, and the probing direction / location changed. That is a very bad thing. Those parts were correct.
Also, what the heck is an X vector? Where do you see that?
For additional info, refer to the attached picture. The outside diameter of the casting has a very loose tolerance. The notch is very small, and cleaned up (i.e. completely changed) with a hand file. The plan was to use points 1 and 2 for the polar radius relative to the base alignment near the notch. Then use that radius in a formula to drop down to the right height to get points on either side of the slot (3 and 4). Point 5 was to be in line with a symmetry point between 3 and 4, with a height relative to the found radius of the outside diameter of the casting.
I can run the measurement plan with my setup casting, but I need formulas to adjust things for production.
Also, knowing things about points seems like a good idea. Especially since the calypso documentation explanations are so amazingly terrible as a general rule of thumb.
In addition, I just changed the bolt pattern holes to polar, and they all give the correct radius (the diameter of the bolt pattern is 8.500), and height (Y value). However, the angle given is wrong. It is giving the angle cw from the +Z in the XZ plane, where the angle format would imply the angle should be ccw from the +X in the XZ plane.
So three differences between my points and my centers:
1.) centers get the correct R
2.) centers get the correct Height
3.) centers at least get angles that are correct magnitudes from a different perspective. The centers of my points seemingly had no relationship to anything.
Why the difference?
I am even more confused than before!!!
Measure the notch as a circle, then form between the hole
in +Z / X0 and the notch an "angle between elements"!
You can calculate the depth of the notch with a formula!
Gregory,
Yes those angle illustrations are confusing. But regarding the screenshot in your most recent post, it is CCW from the +X direction. The angle is in the XY plane, not the XZ plane. Notice the small coordinate system centered on the circle in question.
So what are the definitions?
As in, R = fill in the definition
Angle = fill in the definition
Height = fill in the definition
and so on
Sorry, Gregory. I haven't done much with polar coordinates, so I didn't grasp your question. (I thought you were concerned with the start angle, not the angle in the coordinates of the center of the circle.)
Andreas' point is that the "Space Axis" you select not only determines the orientation of the circle, but also determines the orientation of the axis of the cylindrical coordinate system.
In keeping with the right-hand rule, the following apply when the default angle format is in use (the top option in "Positive orientation"):
If the Space Axis is +Z, Height is the Z coordinate, R is the distance from the Z-axis, and Angle is the angle in XY, starting from the +X direction and moving towards the +Y direction.
If the Space Axis is +Y, Height is the Y coordinate, R is the distance from the Y-axis, and Angle is the angle in ZX, starting from the +Z direction and moving towards the +X direction.
If the Space Axis is +X, Height is the X coordinate, R is the distance from the X-axis, and Angle is the angle in YZ, starting from the +Y direction and moving towards the +Z direction.
If the Space Axis is -Z, Height is the -Z coordinate, R is the distance from the Z-axis, and Angle is the angle in YX, starting from the +Y direction and moving towards the +X direction.
If the Space Axis is -Y, Height is the -Y coordinate, R is the distance from the Y-axis, and Angle is the angle in XZ, starting from the +X direction and moving towards the +Z direction.
If the Space Axis is -X, Height is the -X coordinate, R is the distance from the X-axis, and Angle is the angle in ZY, starting from the +Z direction and moving towards the +Y direction.
Gregory, it looks like the issue is you have selected the +Y space axis, and you're expecting the behavior for the -Y space axis.
Hope that makes the mud a little clearer. 😃
I am confused about something else now...
On a similar casting, I am getting different numbers depending on how I get the characteristic?
a 3d line from Circle 40 to the center of the base alignment (in this case Circle 1) gives me 0.0674
Polar position Angle_Circle 40 gives me 0.0674
the Angle check on the feature window gives me 0.0674
BUT...
getActual("Circle 40").coordPolAngle in a result element gives me 0.0012
what is going on with this?
EDIT: the answer is that result element is evil and changes things to radians without saying anything
0.0012*180/PI()=0.0012*57.2957795131=0.0674
Therefore, new question.
Is there a setting somewhere that addresses this?
