[Mi...] Posted August 6, 2018 Share Posted August 6, 2018 So I am running through some notes on 6.6 and it tells me that I can go from the last 12 to the last 20 on my Table Protocol. Says to change paper size etc... and I did that but I can not get it to read the last 20. I have went through all my PiWeb resources and I came up empty. Is this even possible? Anyone do it want to send me a template LOL.... I do parts on a 20 pc run so it would be great to report all 20 at once instead of 2 sets of 10.... Thanks Link to comment https://qualityforum.zeiss.com/topic/20500-table-protocol-addition/ Share on other sites More sharing options...
[d8...] Posted August 7, 2018 Share Posted August 7, 2018 The TableProtocol.ptx just reports the last 12 measurements. To show the last 20 measurements without editing or creating your own report, you could go to the 'Single Measurements' button and select the last 12, print or PDF, and then go to the 'Single Measurements' button again and select the remaining 8 records, then print or PDF. The cells are designed to show only the last 12 measurements (each cell has been populated with, essentially a formula, pulling Measured Value - 1, Measured Value -2 and so on) so there is no way for it to keep generating additional columns. It's possible to create a report that meets your needs, but it may not end up being TableProtocol.ptx. Link to comment https://qualityforum.zeiss.com/topic/20500-table-protocol-addition/#findComment-116388 Share on other sites More sharing options...
[An...] Posted August 7, 2018 Share Posted August 7, 2018 @Laura, not completely correct, I often need the Taple protocol! I have changed it to 20 measurements, there are some in the PiWeb Designer Changes needed. Link to comment https://qualityforum.zeiss.com/topic/20500-table-protocol-addition/#findComment-116390 Share on other sites More sharing options...
[Mi...] Posted August 7, 2018 Author Share Posted August 7, 2018 Yes Andreas this is what I want to do. How do I change the table to show 20 and not 12? I know I have to resize the page etc. but I cant seem to find how to add the other 8 columns in the table. Link to comment https://qualityforum.zeiss.com/topic/20500-table-protocol-addition/#findComment-116392 Share on other sites More sharing options...
[d8...] Posted August 7, 2018 Share Posted August 7, 2018 Yes, Andreas, it’s definitely possible to modify the report. I’ve also done the same. I apologize, my solution was to provide him with an immediate method, short of editing it himself. Link to comment https://qualityforum.zeiss.com/topic/20500-table-protocol-addition/#findComment-116394 Share on other sites More sharing options...
[An...] Posted August 8, 2018 Share Posted August 8, 2018 Change page to landscape A3, or equivalent to US format click on page structure the eight new tables are inserted automatically after the changes, create the page as a new TapleProtocol_A3! Link to comment https://qualityforum.zeiss.com/topic/20500-table-protocol-addition/#findComment-116396 Share on other sites More sharing options...
[Mi...] Posted August 8, 2018 Author Share Posted August 8, 2018 I did that exact thing. I save it, recall it to use in my program but I still only have 12 results. Ill mess around with it some more, but so far I am coming up empty handed Link to comment https://qualityforum.zeiss.com/topic/20500-table-protocol-addition/#findComment-116398 Share on other sites More sharing options...
[An...] Posted August 8, 2018 Share Posted August 8, 2018 if you open the new TapleProtokol, you have to increase the value "12" in the Menu "Measurements" to the value "20"! Unfortunately, you always have to make this change, but unfortunately I have not found a way that the value "20" remains in the System! Link to comment https://qualityforum.zeiss.com/topic/20500-table-protocol-addition/#findComment-116400 Share on other sites More sharing options...
[Mi...] Posted August 8, 2018 Author Share Posted August 8, 2018 yeah I did that too but nothing. I think PiWeb has the 12 built in as a default.. I have no idea why its not working Link to comment https://qualityforum.zeiss.com/topic/20500-table-protocol-addition/#findComment-116402 Share on other sites More sharing options...
[An...] Posted August 8, 2018 Share Posted August 8, 2018 I'll go over everything in the company tomorrow, maybe I missed something! I had no problems so far! As you can see in my first report, it works! Link to comment https://qualityforum.zeiss.com/topic/20500-table-protocol-addition/#findComment-116404 Share on other sites More sharing options...
[An...] Posted August 9, 2018 Share Posted August 9, 2018 For testing I created a new TapleProtocol and it works like I described it in the picture gallery! Racine Mike, which PiWeb version do you have? I am using version 2018 / 6.6.5.0. Link to comment https://qualityforum.zeiss.com/topic/20500-table-protocol-addition/#findComment-116406 Share on other sites More sharing options...
[Mi...] Posted August 9, 2018 Author Share Posted August 9, 2018 I have 2018 so I have newest version. Cant figure out why Im not seeing 20 UGHHHHHHHH Link to comment https://qualityforum.zeiss.com/topic/20500-table-protocol-addition/#findComment-116408 Share on other sites More sharing options...
[An...] Posted August 9, 2018 Share Posted August 9, 2018 I don't have a solution anymore either! 🙁 call the support! maybe there's a bug in your software! Link to comment https://qualityforum.zeiss.com/topic/20500-table-protocol-addition/#findComment-116410 Share on other sites More sharing options...
[Mi...] Posted August 9, 2018 Author Share Posted August 9, 2018 I still cant get the 20. There has to be something else to this. I cant see the addition of 8 rows just by changing the paper size and measurement qty. I would think you would have to change the header to accept the added 8 rows.. Unless I am way off base here.... Link to comment https://qualityforum.zeiss.com/topic/20500-table-protocol-addition/#findComment-116412 Share on other sites More sharing options...
[An...] Posted August 9, 2018 Share Posted August 9, 2018 You do not have to add anything, after this change the missing lines are generated automatically, they are only not visible in the editing mode! If the log is opened and the number is increased to the value "20", they are then displayed. Link to comment https://qualityforum.zeiss.com/topic/20500-table-protocol-addition/#findComment-116414 Share on other sites More sharing options...
