[Ja...] Posted August 3, 2018 Share Posted August 3, 2018 Hi, I'm trying to figure out how to get the CMM to measure a diameter and a specific distance. It has to be the precise distance. Thanks Link to comment https://qualityforum.zeiss.com/topic/20512-diameter-a-certain-distance-into-a-bore/ Share on other sites More sharing options...
[De...] Posted August 3, 2018 Share Posted August 3, 2018 In the strategy for the circle select circle path. in the circle path you can set the start height. Link to comment https://qualityforum.zeiss.com/topic/20512-diameter-a-certain-distance-into-a-bore/#findComment-116480 Share on other sites More sharing options...
[6f...] Posted August 3, 2018 Share Posted August 3, 2018 You could change the height of the circle in the feature dialog box (ie, change the X, Y or Z value to the correct value) or alternatively, you can use a formula to set the circle X distance away from a particular feature. Link to comment https://qualityforum.zeiss.com/topic/20512-diameter-a-certain-distance-into-a-bore/#findComment-116482 Share on other sites More sharing options...
[Ri...] Posted August 3, 2018 Share Posted August 3, 2018 Jacquelynn, could you provide more details? There are several ways of accomplishing what you need and some will work better then others, depending on circumstances. Link to comment https://qualityforum.zeiss.com/topic/20512-diameter-a-certain-distance-into-a-bore/#findComment-116484 Share on other sites More sharing options...
[Ja...] Posted August 3, 2018 Author Share Posted August 3, 2018 It's the chamber end of a barrel and production need the diameter of the bore 1.600 into the bore from the face of the chamber. Link to comment https://qualityforum.zeiss.com/topic/20512-diameter-a-certain-distance-into-a-bore/#findComment-116486 Share on other sites More sharing options...
[Ri...] Posted August 3, 2018 Share Posted August 3, 2018 Is the face of the chamber part of the Base Alignment or part of a secondary alignment? Link to comment https://qualityforum.zeiss.com/topic/20512-diameter-a-certain-distance-into-a-bore/#findComment-116488 Share on other sites More sharing options...
