[Mi...] Posted August 1, 2018 Share Posted August 1, 2018 Where is the DBS dialog box. CANT find it anywhere.... Ughhh Upgraded to 2018. Has been good until NOW. Only happens on 1 prg.. Link to comment https://qualityforum.zeiss.com/topic/20516-database-snychronization-settings/ Share on other sites More sharing options...
[79...] Posted August 1, 2018 Share Posted August 1, 2018 Resources > Results to File > PiWeb Export configuration. I haven't installed 2018 yet, so hopefully it's in the same spot as 2017... Link to comment https://qualityforum.zeiss.com/topic/20516-database-snychronization-settings/#findComment-116520 Share on other sites More sharing options...
[Mi...] Posted August 1, 2018 Author Share Posted August 1, 2018 Ughh forgot to look in calypso. I was all inside PiWeb. Ill look there when I get done with the present prg i'm running Link to comment https://qualityforum.zeiss.com/topic/20516-database-snychronization-settings/#findComment-116522 Share on other sites More sharing options...
[Mi...] Posted August 1, 2018 Author Share Posted August 1, 2018 That did it. It was under PiWeb Reporting Configuration. I must have checked it somewhere in PiWeb but Im not sure where. Thanks Link to comment https://qualityforum.zeiss.com/topic/20516-database-snychronization-settings/#findComment-116524 Share on other sites More sharing options...
[79...] Posted August 2, 2018 Share Posted August 2, 2018 Ah right, my bad, I didn't have Calypso open. Glad you found it! Link to comment https://qualityforum.zeiss.com/topic/20516-database-snychronization-settings/#findComment-116526 Share on other sites More sharing options...
