O Inspect Z axis
Hello,
We recently got a O-inspect, up to this point I have only used the Duramax. I will be going out for training for it soon but in the meantime I did mess around with it a little bit. I am pretty impressed with the camera but what I realized is that the probe does not reach the stage, it stops short about an inch from the surface. Is this a safety feature to not slam the probes into the glass? Is there anyway to change where the stop is? We will still be using the probes for a lot of jobs and the parts in that department are quite small it would never reach them without fixturing.
Ok thank you guys. I have already added a plate on the stage to get around it but I was hoping to get away from that. I was going to try a longer extension but I was worried that it wasn't so much a physical stop and maybe just programmed in to stop the probe at a certain height. I thought maybe if I got a longer probe after qualifying it would just stop it earlier with the probe at the same height, did not want to buy the extension if it wasn't going to help.
