[Me...] Posted July 24, 2018 Share Posted July 24, 2018 Hello, I would like to add some Pictures of part in fixture for operator reference. When I call up picture in User Information the Picture is cut off in CZViewer. How can I resize? Thanks. Link to comment https://qualityforum.zeiss.com/topic/20554-user-information/ Share on other sites More sharing options...
[Ri...] Posted July 24, 2018 Share Posted July 24, 2018 I would guess Photoshop or something similar would do the trick nicely. I have a Canon specific picture editor for the documentation and instruction photos for programs I write for customers that require it. Link to comment https://qualityforum.zeiss.com/topic/20554-user-information/#findComment-116740 Share on other sites More sharing options...
[To...] Posted July 25, 2018 Share Posted July 25, 2018 Windows Paint program can resize pictures very easily and it's free. Link to comment https://qualityforum.zeiss.com/topic/20554-user-information/#findComment-116742 Share on other sites More sharing options...
[Me...] Posted July 25, 2018 Author Share Posted July 25, 2018 I have always been in the habit of taking the picture then reopening in paint and resizing then I also have the opportunity to add notes if I need as well. Link to comment https://qualityforum.zeiss.com/topic/20554-user-information/#findComment-116744 Share on other sites More sharing options...
[Ra...] Posted July 25, 2018 Share Posted July 25, 2018 This may be a tad overboard, but I make a PDF from an excel spreadsheet. A redacted example is attached. I use excel to keep all set-up documents consistent. I can resize, crop, and align images in the spreadsheet. AND, I embed a link to the print right in excel. For more complicated set-ups, I embed additional links to even more PDF resources - part families, unique fixtures, enlarged photos. I "programmed" drop-down menus in excel with tool sets to populate the stylus information with one click. I can get from photos to a PDF in minutes. When attached as user information from Calypso, the operator has many resources from one document by which to load a part.Operator Set-up Sheet.pdf Link to comment https://qualityforum.zeiss.com/topic/20554-user-information/#findComment-116746 Share on other sites More sharing options...
[Mi...] Posted July 25, 2018 Share Posted July 25, 2018 I use xls also and it works great. I even made a vid of some of the set ups to make sure it done correct. Easy peasy Link to comment https://qualityforum.zeiss.com/topic/20554-user-information/#findComment-116748 Share on other sites More sharing options...
[Me...] Posted July 25, 2018 Author Share Posted July 25, 2018 Thanks a lot for all the replies. I was able to resize with paint. Once I Figured out the size I was able to do the same thing with all my pictures real easy. I like the White Block with the colored arrows. That is an excellent Idea for showing the machine direction in the pictures. Link to comment https://qualityforum.zeiss.com/topic/20554-user-information/#findComment-116750 Share on other sites More sharing options...
[Me...] Posted July 26, 2018 Author Share Posted July 26, 2018 Thanks I had it made on a 3D printer we have had great success using it. Link to comment https://qualityforum.zeiss.com/topic/20554-user-information/#findComment-116752 Share on other sites More sharing options...
[Me...] Posted July 26, 2018 Author Share Posted July 26, 2018 Hi Randy, How do you link your excel set up instruction to individual program? Please advise. Link to comment https://qualityforum.zeiss.com/topic/20554-user-information/#findComment-116754 Share on other sites More sharing options...
[Ri...] Posted July 26, 2018 Share Posted July 26, 2018 Open the plan you wish to have the exel set up instruction attached to and go to Plan/User Definable measurement run info for CNC start/Select. That will open up a browser so you can track down the xls you want to use. Select the xls and it will open so you can verify it's the correct one and if it is you can close it. Now, go to Resources/Measurement Plan Comment and write something like, "if you don't know how to load the part, click on the User Information button on the Start Measurement field". What happens when you do that is that instruction will be in the comment field, immediately under the measurement plan name on the Start Measurement field. Train your operators to look for it and when they have any questions, they will click on the User Information button at the bottom of the Selection column on the Start Measurement field and the instructions will launch. Link to comment https://qualityforum.zeiss.com/topic/20554-user-information/#findComment-116756 Share on other sites More sharing options...
[Me...] Posted July 26, 2018 Author Share Posted July 26, 2018 We have been using this as our text in the Measurement Comment field and our operators now look for it and then use the photos. **************************************************************** ****** Click on USER INFORMATION for set-up picture ****** **************************************************************** Link to comment https://qualityforum.zeiss.com/topic/20554-user-information/#findComment-116758 Share on other sites More sharing options...
[Mi...] Posted July 26, 2018 Share Posted July 26, 2018 Also... just a tid bit, store/save your xls sheet in the inspection folder for the part that it pertains too. That way when you need to edit it, you know exactly where it is. I have mine set up that way and it works great!!!!!! Just a thought... Link to comment https://qualityforum.zeiss.com/topic/20554-user-information/#findComment-116760 Share on other sites More sharing options...
[Ri...] Posted July 26, 2018 Share Posted July 26, 2018 Excellent advise Mike. Link to comment https://qualityforum.zeiss.com/topic/20554-user-information/#findComment-116762 Share on other sites More sharing options...
[An...] Posted July 27, 2018 Share Posted July 27, 2018 first Step second Step third Step ready Link to comment https://qualityforum.zeiss.com/topic/20554-user-information/#findComment-116764 Share on other sites More sharing options...
