Characteristic Output
Hey everyone,
Is there a way to filter or select what part of the characteristic actually gets imported into our custom PiWeb report? (ex.) For true positions, the basic dimensions also get uploaded. We only want the tolerance to get imported because our basic dimensions already have their own "bubble" dimensions. Any suggestions would be appreciated.
Thank You
https://qualityforum.zeiss.com/topic/20584-characteristic-output/
Thanks for the clarification. Here is a suggestion:
In Designer, you may want to turn on this particular characteristic filter. My guess is, you had Additional Printout turned on at one point so the characteristic was generated and pushed to Planner. So although these X and Y characteristics exist now, with Additional Printout turned off there is no result being pushed to them any longer. (I'm speculating here without being able to see what you're working on...)
Please try the following:
Select your characteristic table. Go to the filter icon in the bottom corner of your Data Provider tab.
Turn on the 'Only Characteristics with Measured Data' filter. Close the dialog and save your report.
Let me know if this works for you.
Laura
https://qualityforum.zeiss.com/topic/20584-characteristic-output/#findComment-116916
Thank you for the help Laura! I'm still trying to get the template to work right but I think the filter is putting me in the right direction. I think right now it is an issue of the filter not being applied to the entire table. No results show up, but it leaves blank rows where the results would be.
https://qualityforum.zeiss.com/topic/20584-characteristic-output/#findComment-116922
Ok Laura, you win...LOL
I saw a similar issue from someone who was trying to re-arrange the columns in their template. They deleted a field and when they tried to re-create it, the actuals would not appear. We tried everything but just could not get it to re-connect to the data. End result, they started over.
https://qualityforum.zeiss.com/topic/20584-characteristic-output/#findComment-116924
Harrison, if you want to DM me I can try and help you. I would need your .ptx and if you go in Planner to Help > Save configuration and send the QDB also. Although if you just received SBS you should be on an SMA and Zeiss directly would be able to remote in to you and see what the issue is. Either way, if you need further help I'm here with any questions you may have.
https://qualityforum.zeiss.com/topic/20584-characteristic-output/#findComment-116926
