[La...] Posted July 19, 2018 Share Posted July 19, 2018 I have some Axles that I have to move the Rack from the back of the table, and put it out of the way. Is there a way to save multiple rack locations so when I have to move the rack (which I put to the right side of the table) I can still do an automatic stylus system change? Thank you for your help!!! Link to comment https://qualityforum.zeiss.com/topic/20588-auto-stylus-change-rack/ Share on other sites More sharing options...
[No...] Posted July 20, 2018 Share Posted July 20, 2018 You can't have 2 different rack locations, but it may be possible to define an additional set of probe holders with different positions. You could use "A" for the normal position and "A1" for the alternative position. Then you'd either swap the probes to the other holders by hand or you save two different configurations, one with the probes in A,B,C... and the other in A1,B1,C1... Link to comment https://qualityforum.zeiss.com/topic/20588-auto-stylus-change-rack/#findComment-116946 Share on other sites More sharing options...
