Auto Stylus Change Rack
I have some Axles that I have to move the Rack from the back of the table, and put it out of the way. Is there a way to save multiple rack locations so when I have to move the rack (which I put to the right side of the table) I can still do an automatic stylus system change? Thank you for your help!!!
You can't have 2 different rack locations, but it may be possible to define an additional set of probe holders with different positions. You could use "A" for the normal position and "A1" for the alternative position. Then you'd either swap the probes to the other holders by hand or you save two different configurations, one with the probes in A,B,C... and the other in A1,B1,C1...
