How to programme/ check this?
Lots of constructed features
circle around each end ends, total of 6.
Construct a theoretical circle out of the center point of the 6 circles.
Construct 6 intersections from each end circle to the constructed circle.
Construct 6 lines from the center of the constructed circle (or your datum circle) to each intersection.
Angle between features for constructed lines 1&2, 3&4, 5&6.
Take a long lunch.
As for the "Equally Spaced", you could add 3 more angles from lines 1&3, 3&5, 5&1, or you could take a centerpoint between circles 1&2 and construct a 3d line for the center of each slot, or you could create a symmetry line between lines 1&2, 3&4, 5&6.
But i don't know how to quantify "Equally Spaced". tolerance would be nice.
I took a little time and wrote a quick program, extract it and take a look.....
Forum4 Angles.zip
