[Da...] Posted June 29, 2018 Share Posted June 29, 2018 Does anyone know why the PMI information is not showing up a CATIA V model with PMI in Calypso 2017? Calypso CAD Log File.PNGFetching info... PMI Import Settings.PNGFetching info... Link to comment Share on other sites More sharing options...
[Ri...] Posted June 29, 2018 Share Posted June 29, 2018 What version is the Catia V. Calypso 2017 works with up to V5R8-V5-6R2017. If your Catia V is a version newer, then all bets are off. If you do have a compatible version of Catia, then I would look for something in the model that you can't see that's giving Calypso a case of the yips. Another test you might try is to see if the model loads without extracting the PMI. Link to comment Share on other sites More sharing options...
[Da...] Posted July 2, 2018 Author Share Posted July 2, 2018 Rich, The CATIA file loads fine in calypso, but no PMI is present. The cad log file shows PMI is present. Do you think the reason why the PMI is not showing up is due to the version of CATIA they are using? Link to comment Share on other sites More sharing options...
[Ri...] Posted July 2, 2018 Share Posted July 2, 2018 Double check Cad/Cad Model Control/Show PMI from CAD has a check mark next to it on the menu. If not, left click on it and restart Calypso. Then load the model in question. Link to comment Share on other sites More sharing options...
[Me...] Posted July 2, 2018 Share Posted July 2, 2018 The version of Catia used to create the file in question is: V5-6R2016_26 Link to comment Share on other sites More sharing options...
