Radio Button in PCM
AAAhhhhh! I KNEW you'd have it.
I absolutely do NOT need it. However, I could put it to use constructively.
I found radio buttons for PiWeb, but not PCM. I'm only at 5.8, though. *shame* Could this be why I didn't find documentation for radio buttons? Or (as I suspect), do you simply have knowledge beyond mere mortals?
It's been a bank holiday, I've been drunk and when I got back to work I got overflooded with other peoples urgent problems and a potentially broken kmz-portal... So I've had zero time to spare.
This is not documented anyware, and it falls out side of what you are supposed to do with PCM and Calypso. However, this can be done fairly simple. I'll give you an example that you can play around with as soon as people start to bug off, I just need time to write a working example, not just the UI 🙂
I truly expected that you were faking the radio button frame with a graphics program. I should have expected that you ACTUALLY have a method to do this.
Cheers to your drunken holiday!
Graphics program? Well the only one Iv'e ever used is paint, all I ever needed since windows 3.11. It's not my cup of tea.
I'll get to it tomorrow, there will be a service tech here to look at the kmz. That will give me some time to crawl in to my batcave and do stupid stuff.
