[Ra...] Posted June 21, 2018 Share Posted June 21, 2018 Title says it all: Does PCM support radio buttons? Drop-downs are useful; radio buttons are awesome. Link to comment Share on other sites More sharing options...
[Er...] Posted June 21, 2018 Share Posted June 21, 2018 Like this? Link to comment Share on other sites More sharing options...
[Ra...] Posted June 21, 2018 Author Share Posted June 21, 2018 AAAhhhhh! I KNEW you'd have it. I absolutely do NOT need it. However, I could put it to use constructively. I found radio buttons for PiWeb, but not PCM. I'm only at 5.8, though. *shame* Could this be why I didn't find documentation for radio buttons? Or (as I suspect), do you simply have knowledge beyond mere mortals? Link to comment Share on other sites More sharing options...
[Da...] Posted June 22, 2018 Share Posted June 22, 2018 As far as I know there's no way to do this. We are on 6.4.14 at the moment... Link to comment Share on other sites More sharing options...
[Er...] Posted June 25, 2018 Share Posted June 25, 2018 It's been a bank holiday, I've been drunk and when I got back to work I got overflooded with other peoples urgent problems and a potentially broken kmz-portal... So I've had zero time to spare. This is not documented anyware, and it falls out side of what you are supposed to do with PCM and Calypso. However, this can be done fairly simple. I'll give you an example that you can play around with as soon as people start to bug off, I just need time to write a working example, not just the UI 🙂 Link to comment Share on other sites More sharing options...
[Ra...] Posted June 26, 2018 Author Share Posted June 26, 2018 I truly expected that you were faking the radio button frame with a graphics program. I should have expected that you ACTUALLY have a method to do this. Cheers to your drunken holiday! Link to comment Share on other sites More sharing options...
[Er...] Posted June 26, 2018 Share Posted June 26, 2018 Graphics program? Well the only one Iv'e ever used is paint, all I ever needed since windows 3.11. It's not my cup of tea. I'll get to it tomorrow, there will be a service tech here to look at the kmz. That will give me some time to crawl in to my batcave and do stupid stuff. Link to comment Share on other sites More sharing options...
