[Me...] Posted June 19, 2018 Share Posted June 19, 2018 Hello everyone, I have a program that I'm running as a pallet in autorun. The program works and generates a report for each individual part. I've been asked to generate a report that includes all four parts on a single report. I have calypso 6.4 and piweb plus 6.2 It seems like the only option I have is setting it up with the last (certain number) of measurements. I would like for each measurement table to be dedicated to a fixed location on the fixture. I know there must be a way, I just cant seem to get going in the right direction. I appreciate any help I can get Kyle Link to comment Share on other sites More sharing options...
[Mi...] Posted June 19, 2018 Share Posted June 19, 2018 Do you have the full version of PiWeb?? So If I read correct you have 4 parts/pallet pos. A B C D. You want all of pallet A on one table and all of B on another etc.. The table in PiWeb will only show the last 12. Only way I can think of is if you put in a search variable in the Piweb report header and then entered the pallet pos in this section when you ran the pallet. You could then do a search for the pallet positions. I have done this but not with pallets, but rather by shift number. Only thing I can come up with off top of my head. Might be some coding you can do, but not sure what all will work with the ol PiWeb Link to comment Share on other sites More sharing options...
[5b...] Posted June 21, 2018 Share Posted June 21, 2018 You could assign a measurement attribute called Pallet # and then have a measurement attribute filter on each table in your report. So if it's measured on pallet location 1, the result will show up in that particular location in your report as well. Does this make sense / answer your question? Link to comment Share on other sites More sharing options...
