[Ja...] Posted June 19, 2018 Share Posted June 19, 2018 Hello, I have never come across this in my programming travels. I'm unsure of the best way to approach this one. ThanksNot Sure.jpg Link to comment https://qualityforum.zeiss.com/topic/20726-not-sure-on-this-one/ Share on other sites More sharing options...
[Da...] Posted June 19, 2018 Share Posted June 19, 2018 Not sure what the feature really is, but this will more or less get you there. Check the cylinder. Check the face. Ask for the intersection ( point) now create a secondary alignment. Use special and rotate the alignment to 38 Degrees. Check whatever that feature is and ask for a Cartesian distance. from the feature to the intersect point , using the secondary alignment. I am assuming that the angle is basic... Link to comment https://qualityforum.zeiss.com/topic/20726-not-sure-on-this-one/#findComment-117832 Share on other sites More sharing options...
[Ja...] Posted June 19, 2018 Author Share Posted June 19, 2018 The feature is a feed ramp. The 38 degrees is the incline of the feed ramp. I got the intersection done. The secondary alignment I'm not super familiar with, but I'll give it a whirl Link to comment https://qualityforum.zeiss.com/topic/20726-not-sure-on-this-one/#findComment-117834 Share on other sites More sharing options...
[Da...] Posted June 19, 2018 Share Posted June 19, 2018 it's in Resources , Utilities ...Alignment at the top. Link to comment https://qualityforum.zeiss.com/topic/20726-not-sure-on-this-one/#findComment-117836 Share on other sites More sharing options...
[Ja...] Posted June 19, 2018 Author Share Posted June 19, 2018 Also I can't get the distance to select the secondary alignment Link to comment https://qualityforum.zeiss.com/topic/20726-not-sure-on-this-one/#findComment-117838 Share on other sites More sharing options...
[Ja...] Posted June 19, 2018 Author Share Posted June 19, 2018 I found where it is and set it to 38 degrees Link to comment https://qualityforum.zeiss.com/topic/20726-not-sure-on-this-one/#findComment-117840 Share on other sites More sharing options...
[Da...] Posted June 19, 2018 Share Posted June 19, 2018 looking really close at your print , I'm not sure where that dimension line originates. Check the rest of the views to see if you can verify the origin. Link to comment https://qualityforum.zeiss.com/topic/20726-not-sure-on-this-one/#findComment-117842 Share on other sites More sharing options...
[Ja...] Posted June 19, 2018 Author Share Posted June 19, 2018 center of the Cylinder Link to comment https://qualityforum.zeiss.com/topic/20726-not-sure-on-this-one/#findComment-117844 Share on other sites More sharing options...
[Da...] Posted June 19, 2018 Share Posted June 19, 2018 Try Simple distance, It has an alignment option...Use which ever axis you require. Link to comment https://qualityforum.zeiss.com/topic/20726-not-sure-on-this-one/#findComment-117846 Share on other sites More sharing options...
[Da...] Posted June 19, 2018 Share Posted June 19, 2018 Please sign in to view this quote. But is it at the shoulder face? Link to comment https://qualityforum.zeiss.com/topic/20726-not-sure-on-this-one/#findComment-117848 Share on other sites More sharing options...
[Ja...] Posted June 19, 2018 Author Share Posted June 19, 2018 yes Link to comment https://qualityforum.zeiss.com/topic/20726-not-sure-on-this-one/#findComment-117850 Share on other sites More sharing options...
[Ja...] Posted June 19, 2018 Author Share Posted June 19, 2018 yes it is the shoulder face Link to comment https://qualityforum.zeiss.com/topic/20726-not-sure-on-this-one/#findComment-117852 Share on other sites More sharing options...
[Da...] Posted June 19, 2018 Share Posted June 19, 2018 Are you getting anywhere? Link to comment https://qualityforum.zeiss.com/topic/20726-not-sure-on-this-one/#findComment-117854 Share on other sites More sharing options...
[Ja...] Posted June 19, 2018 Author Share Posted June 19, 2018 I got everything done like you said and It measures way off. Maybe I'm missing something still. Link to comment https://qualityforum.zeiss.com/topic/20726-not-sure-on-this-one/#findComment-117856 Share on other sites More sharing options...
[Ja...] Posted June 19, 2018 Author Share Posted June 19, 2018 The closest I have gotten is .4493 Link to comment https://qualityforum.zeiss.com/topic/20726-not-sure-on-this-one/#findComment-117858 Share on other sites More sharing options...
