How to prevent Probe change moving to Z+ Clearance Plane?
I have a large part where I need to Block X- and Z+ axis. The program works fine until I have to change to another tool.
When the tool change starts, the CMM ignores the Blocked Z+ axis and over travels.
If I perform a probe change from "Automatic stylus system change" dialog box it works fine.
How do I prevent the probe change from moving to the Z+ Clearance Plane?
there are a lot of ways to accomplish this. If you go to plan navigation travel performance during stylus change. that will probably work the best. this with a combination of position points might do the trick.
also you can modify the clearance data per feature by double clicking the clearance data in the feature strategy. move to clearance before, after, or not at all.
