How to delete CAD model from Start Template
Hey everyone!
I have been using a start template with all my defaults and loaded a CAD model which got saved into my template file. I wondered if there is a way to delete or "un-load" it from the program? Any help is appreciated! Thanks!
You should be able to go to cad, select view and select Delete (about 10th option down on the list) to remove it but, sometimes that doesn't work permanently and the model will still be there the next time the program is opened.
So, to permanently delete it, you have to open the program folder up in windows explorer and select the "model.sab" (or whatever version your Calypso licences uses) and delete it from the folder and then the model will not be there the next time you open the program in Calypso.
Within the folder of the template (or any CMM program) should be three or four files (It varies).
Find these files and remove/delete them:
model.fct
model.sab
model_eval.sab
