How to delete CAD model from Start Template
You should be able to go to cad, select view and select Delete (about 10th option down on the list) to remove it but, sometimes that doesn't work permanently and the model will still be there the next time the program is opened.
So, to permanently delete it, you have to open the program folder up in windows explorer and select the "model.sab" (or whatever version your Calypso licences uses) and delete it from the folder and then the model will not be there the next time you open the program in Calypso.
