[Da...] Posted June 12, 2018 Share Posted June 12, 2018 Hello guys I have been asked if I can make important characteristics to be highlited or bolted or what ever makes them seperate. I am using calypso 5.4 and basic PiWeb only. Any ideas ? Link to comment https://qualityforum.zeiss.com/topic/20776-hihglited-features-on-the-report/ Share on other sites More sharing options...
[b6...] Posted June 12, 2018 Share Posted June 12, 2018 Hi Daniel, Do you mean you are using Basic Reporter? Does Basic Reporter support characteristic filters based on characteristic attributes? It's been a good 5 years since I've used Basic Reporter so I don't recall. With the new PiWeb Reporter (which is like Basic Reporter but 5,000,000 times better) you can make 1 generic report and have characteristics easily split into critical / not critical by using characteristic attributes. Okay - actually, I just checked and it doesn't seem like Basic Reporter supports that function. Bummer. Link to comment https://qualityforum.zeiss.com/topic/20776-hihglited-features-on-the-report/#findComment-118182 Share on other sites More sharing options...
[Me...] Posted June 12, 2018 Share Posted June 12, 2018 If you're using Basic Reporter, you could put all the characteristics in question into a group and then place the group at a desired point like the beginning or end of the report. Link to comment https://qualityforum.zeiss.com/topic/20776-hihglited-features-on-the-report/#findComment-118184 Share on other sites More sharing options...
[Da...] Posted June 13, 2018 Author Share Posted June 13, 2018 This is what I have done now. Can I output name of the group on the report ? Link to comment https://qualityforum.zeiss.com/topic/20776-hihglited-features-on-the-report/#findComment-118186 Share on other sites More sharing options...
