Calibration
These are projection angles.
If my memory serves me, it's backward from what you'd expect and points up the probe. Imagine a vector with its origin at the center of the probe tip and pointing back along the shaft.
Calypso assumes the vector is somewhere near the Z axis since you beeped your manual point within 45 degrees of the top of the qualification sphere. It is asking for the angle from the Z axis toward the Y axis (YZ projection) and the angle from the Z axis toward the X axis (XZ projection).
https://qualityforum.zeiss.com/topic/20790-calibration/#findComment-118268
