Cylinder Stylus on O-Inspect XXT
Is it possible to add and qualify a ruby cylinder stylus system on our O-Inspect 322? Specifically a Q-Mark TM3-1516-B-TX or similar.
If the cylinder probe has a full radius at the bottom, it is my opinion that you could qualify it as a standard spherical radius probe. One thing to note is, the deeper that you measure along the cylindrical portion of the stylus, the further away from the radius's center point you'll be as the stylus pivots. I suggest staying as close to the end of the probe as possible when measuring.
