[Me...] Posted May 4, 2018 Share Posted May 4, 2018 I have 4 stations and I can't get any of them to automatically print out the PiWeb report at the end of the run. What have I got set wrong? Link to comment Share on other sites More sharing options...
[Me...] Posted May 4, 2018 Author Share Posted May 4, 2018 Is your main report your own or are you using the templates provided? If you are using your own I think you need to point to where they need to be located to the server. Link to comment Share on other sites More sharing options...
[Me...] Posted May 4, 2018 Author Share Posted May 4, 2018 Are you using Basic or have you upgraded to something else? Link to comment Share on other sites More sharing options...
[Me...] Posted May 4, 2018 Author Share Posted May 4, 2018 I'm using what comes standard in 6.4. I modified the standard PiWeb report and saved it as something else. I'm not real network savvy. Would you clarify your statement about location please? Thanks. Link to comment Share on other sites More sharing options...
[Me...] Posted May 4, 2018 Author Share Posted May 4, 2018 So I ran into this same issue. You will need to create the same report for all the machines because it is local to the computer at this point since you do not have any of the upgrades. Also make sure that you are pointing to the report you want to use as well. Link to comment Share on other sites More sharing options...
[Me...] Posted May 4, 2018 Author Share Posted May 4, 2018 I made a copy of the report for each machine already. I don't know what you mean by "pointing to the report". Link to comment Share on other sites More sharing options...
[Me...] Posted May 4, 2018 Author Share Posted May 4, 2018 The default is not your report it is the Zeiss Standard Protocol one so you will need to make sure that it is using the one you have created instead. Link to comment Share on other sites More sharing options...
[Me...] Posted May 4, 2018 Author Share Posted May 4, 2018 Gotcha. The problem now is that I can't find where to change it. Link to comment Share on other sites More sharing options...
[Me...] Posted May 8, 2018 Author Share Posted May 8, 2018 Bump. Does someone know where to go to change the pointer? Link to comment Share on other sites More sharing options...
[Me...] Posted May 9, 2018 Author Share Posted May 9, 2018 Jack, Look at you private messages for further information. I sent you some information that I could not attach. Link to comment Share on other sites More sharing options...
[Me...] Posted June 4, 2018 Author Share Posted June 4, 2018 Hi, guys i have the same problem i can't make the standard protocol to be automaticaly printed...the protocol it is generated using PiWeb report. When i activate multiple printouts and set my edited standard protocol, it only display the protocol but does not print it. The print button it is activated in multiple printout and at the same time în start measurement window the option send results to printer it is also activated. Please can you guys help me with this problem?? How to fixx it? Link to comment Share on other sites More sharing options...
[Ma...] Posted June 4, 2018 Share Posted June 4, 2018 Hi, maybe you must use the right printer: Not the default printer you must define them: ➡️ I hope thaht works. 2018-06-04_16h48_38.pngFetching info... Link to comment Share on other sites More sharing options...
