report header
How do I get the report to show serial number? I have it asking for it at program run but cant get it on the report header. keep trying to edit the header to add serial number to it but cant find it any where.
1. Go in and add it to the user fields at Resources>>>Design PO>>>>Editor for user defined PO Header.
2. Open up Multiple PO's tab and click the Select PO Header variables bar
3. Click the serial number box on the left. I use the RUN box so that the operator can change the serial Number.
4. Add the Serial number variable to your report header and it should show up.
If you need help on adding this to the actual report let me know. Tell you what I did..
