[Da...] Posted May 17, 2018 Share Posted May 17, 2018 Has anyone ever used a Curve Jump Tolerance? If so, can you share examples where this was used? Link to comment Share on other sites More sharing options...
[Ow...] Posted May 17, 2018 Share Posted May 17, 2018 Curve Jump Tol is explained, I think, on like page 50. http://www.conceptmachine.com/calypsous ... lights.pdf Link to comment Share on other sites More sharing options...
[De...] Posted May 17, 2018 Share Posted May 17, 2018 Curve jump tolerance is used when you have a refining tolerance on a curve of not more than X deviation over X amount of distance. For example I had a part that required this where it had a curve profile that was called out as a .001 profile overall with no more than .0002 profile in any .125 segment. Curve jump allows you to check that second part of it or at least it did, I last used it in version 4. something.. so I cannot attest to whether or not it still functions the same way in the current version. Link to comment Share on other sites More sharing options...
[Da...] Posted May 22, 2018 Author Share Posted May 22, 2018 Owen & Derek, Thanks for the information! This was very helpful! Link to comment Share on other sites More sharing options...
