Error 409
I keep getting this error when i go to run a certain program. It only occurs on 2 features that are using that stylus and within the same clearance group +Z. The setup is Calypso on an older Mitutoyo with a Renishaw Probe.
Error: 409-Y-Axis out of volume
One thought I have is before it drives you too crazy have you tried recreating the feature? Perhaps it just got corrupted?
So far i've recreated the feature, did 400 power cycles. I had Zeiss Tech Support look into it, all with no results.Last thing is i'm doing a software update to see if it's a bug with the Calypso/Mitutoyo set-up.
