Excel report naming
Is it possible to have the mini plan name used when saving excel reports, or am I stuck with just the measurement plan name?
With most of the other report types, you can build a custom file name using "name for output files" by incorporating the "run" variable in the naming string. However, I don't where to go with Excel. I'm guessing you might need to have the "run" variable somewhere in the template but I don't know where the naming convention is controlled.
