[Ro...] Posted May 17, 2018 Share Posted May 17, 2018 Is it possible to have the mini plan name used when saving excel reports, or am I stuck with just the measurement plan name? Link to comment https://qualityforum.zeiss.com/topic/20898-excel-report-naming/ Share on other sites More sharing options...
[To...] Posted May 17, 2018 Share Posted May 17, 2018 With most of the other report types, you can build a custom file name using "name for output files" by incorporating the "run" variable in the naming string. However, I don't where to go with Excel. I'm guessing you might need to have the "run" variable somewhere in the template but I don't know where the naming convention is controlled. Link to comment https://qualityforum.zeiss.com/topic/20898-excel-report-naming/#findComment-118872 Share on other sites More sharing options...
