ID chip
Hi, I keep getting a warning that says "unable to read ID 001 etc, ID chip may be defective" anyone know what this means, Thanks in advance
Shay Wallace | 03-23-2018 12:56 PM |
There is a microchip in the adapter plate. It's designed to hold the name of your stylus system to prevent the accidental mis-loading of a stylus system. I suppose you could have a defective one, but it may just need to have the id re-taught to it.
Go ahead and mount the stylus system in the XXT sensor. Go into the probing system qualification window. At the upper left corner, click the icon for Stylus System Management. In the left hand side, select the stylus system that is mounted and then click the Teach ID over on the lower right side. That should do it, unless there is something wrong with the adapter plate.
You can also turn the ID Chip off if you don't want to use it. Go to the CMM settins window, select Probe on the right, un-tick ID Chip at left.
Tom Oakes | 03-23-2018 01:23 PM |
Tom, What Calypso version did that feature show up in? I'm in the process of updating everything to 6.4, new computers and all. Still running 5.4.
Alan Ryerson | 03-23-2018 03:15 PM |
I think back in 6.0 but definitely in 6.2.
What I saw was that if you had an older machine, it remained OFF after upgrading to the version that used it. And, new machines were shipped with it ON.
Tom Oakes | 03-23-2018 05:00 PM |
The ID sensor for the XXT is terrible, especially if the machine is out on the floor. If the smallest of debris gets on it, you will get this error.
I'd turn it off.
Richard Shomaker | 03-26-2018 03:25 PM |
  • 1 month later...
The ID Chip at this point, doesn't help me since we use the same stylus systems on both of our Conturas. How do I configure it where it is not used, even when the system is shut off and restarted? Every time the system is shut off and restarted, I have to manually go in and shut it off again.
I just tested this on my machine. At the home page, I selected Change Settings > CMM > Probe. Then, I un-checked Activate under ID Chip Recognition. Then, I clicked APPLY. Then, OK. Shut everything down. Re-started the CMM and the checkbox was still un-checked.
Richard,
I get it but wouldn't you want to know if there was debris on the adapter plate? I realize it might be aggravating but so isn't a questionable measurement.
