How Does Calypso Calculate Bilateral unequal dist. on profile
Hey all..
We just recently started calling out profiles on our parts that have unequal bilateral distribution. I know on a regular profile, calypso takes the furthest point from nominal and multiplies it by 2 to get a profile value. My question is how does it do it on a unequal distribution? If I was a total of 0.016" with an U of 0.003", I'd obviously be out if I was on the inside any more then 0.0015". Any help would be appreciated.
Thanks,
Ryan
From my understanding Calypso will find the center point of the tolerance zone and treat it like a standard bilateral from that point.
In your case .016 total with .003 inside, calypso would center the zone at .005 outside and you would get .008 maximum + or -.
So if you had a perfect part that measured 0.0 for the profile, the physical surface would be +.005 from the cad model surface.
For whatever reason i cannot attach the "ProfileCalls" calypso profile guide.......
I'm with Roberto on this, except for one minor point. a U 0 0.003 would mean 0.003 outside the part, so the tolerance would be centered on -0.005.
So would that mean if I ran the part and everything ran dead nuts on, would I have a value of 0.010"? I.E. since the tolerance is centered at -0.005" and I'm running at 0 (or the nominal of the part) that I would then be above the tolerance center zone? Appreciate the fast responses you all have. Thanks for the insight so far.
Yes, at print nominal you would have a profile deviation of about .010
I also agree with Aaron, i think i got my inside & outside flipped
