Rectangle XY tolerance for True Position of Bore Pattern
Hello ,
I have a problem with Rectangle tolerance frame when I measure a true position of a bore pattern. The tolerance frame doesn't rotate with pattern . In the drawing I have tolerance : 0.3 circumferential and 0.5 radial ! 362_a29ce81e03b72c71a0328f7d33ae6ac7.jpg
Ok, then I have to reformulate ; how can I do in Calypso the rotate of the tolerance frame ( to follow the Radius and Angle ) ?
Thank you very much for your description but I don't think that this it's simple to apply. I think that Zeiss should consider to make some change in this direction .
I think that it wood be much simple if I will do a simple True Position of every bore related to center of the ring and just rotate the base alignment, according to the drawing and use Rectangle tolerance frame .
Is that even a legit call out? Whenever I have seen position without the Ø, it applied to only 1 axis, like position of a slot width. Does that call out really mean a square zone or is it just a bad call out?
Just curios....
You could consider it an equivalent of what Y14.5 refers to as a bidirectional tolerance, using the polar coordinate method. (See Y14.5-2009 Figure 7-29 and 7.4.4.2.)
