[Me...] Posted May 10, 2018 Share Posted May 10, 2018 So i found if you use the scroll wheel and zoom in to what i think is basically the limit then zoom back out and look at the cad model it looks all messed up. I'm assuming this is not supposed to happen?Capture.PNG Link to comment https://qualityforum.zeiss.com/topic/20914-bug/ Share on other sites More sharing options...
[Me...] Posted May 10, 2018 Author Share Posted May 10, 2018 I am not seeing this when i try it. It sounds like a graphics card issue. does this issue stick when you open or close it? Link to comment https://qualityforum.zeiss.com/topic/20914-bug/#findComment-118978 Share on other sites More sharing options...
[Me...] Posted May 10, 2018 Author Share Posted May 10, 2018 No, and i'm using the computer that came with the Zeiss Link to comment https://qualityforum.zeiss.com/topic/20914-bug/#findComment-118980 Share on other sites More sharing options...
[Ja...] Posted May 10, 2018 Share Posted May 10, 2018 Have you tried to go into CAD-settings-image quality, and hit apply? I usually have to do that if I zoom in on a small feature. Link to comment https://qualityforum.zeiss.com/topic/20914-bug/#findComment-118982 Share on other sites More sharing options...
[Ca...] Posted May 10, 2018 Share Posted May 10, 2018 I can also get this to fritz out. I just zoomed all the way in, and sometimes the CAD model graphic get visually corrupted. I can get it to snap out of it by toggling the "Show CAD Model" buttons. It's not a huge problem, and as best I can tell, it's only cause by something I have no real reason to do. Link to comment https://qualityforum.zeiss.com/topic/20914-bug/#findComment-118984 Share on other sites More sharing options...
[Ro...] Posted May 11, 2018 Share Posted May 11, 2018 Our PC that came with the Contura only had 6gig of ram from the factory. I was having some general problems and our it guy bumped it up to 18gig, and now it runs much better. I wasn't having the same problem you are, but i wouldn't assume that just because that computer came with the CMM that its ideal. Especially after several years of use. Link to comment https://qualityforum.zeiss.com/topic/20914-bug/#findComment-118986 Share on other sites More sharing options...
[Me...] Posted May 15, 2018 Author Share Posted May 15, 2018 Does this happen to all your cads? Or all the cads from one company? Is the monitor new? Some older monitors had trouble with refresh. But I' thinking your video card may need latest drivers. Ram in your computer is not relevant to video unless it's an onboard chip. Though more is always better. Have you healed your models? I've got models from one company that I cannot heal. They disappear. Link to comment https://qualityforum.zeiss.com/topic/20914-bug/#findComment-118988 Share on other sites More sharing options...
[Da...] Posted May 16, 2018 Share Posted May 16, 2018 I have had simillar problem. I have asked Zeiss support and they have sent me a service pack, but to be honest I have also noticed that the problem was with this practicular cad model. The other ones were ok but service pack was helpfull anyway. Link to comment https://qualityforum.zeiss.com/topic/20914-bug/#findComment-118990 Share on other sites More sharing options...
