[Ji...] Posted May 4, 2018 Share Posted May 4, 2018 I am trying to combine 2 points from a ring in one alignment with 2 points from another ring in another alignment to create one complete circle (See Graphics.JPG). PC-DMIS has something called Equate Alignment. Does anyone know how this can be done in Calypso?Graphics.JPG Link to comment https://qualityforum.zeiss.com/topic/20952-combining-features-from-different-alignments/ Share on other sites More sharing options...
[Pa...] Posted May 4, 2018 Share Posted May 4, 2018 Can you measure the 4 points individually and just recall them to create a theoretical circle? PS-the 4 points don't look like they would create a circle. Am I missing something here? Link to comment https://qualityforum.zeiss.com/topic/20952-combining-features-from-different-alignments/#findComment-119262 Share on other sites More sharing options...
[Ji...] Posted May 5, 2018 Author Share Posted May 5, 2018 Thanks for the reply, Paul. My goal is to try to take a ring with an ID and an OD that is split into 2 halves, measure them separately and then evaluate the halves as if the were assembled by equating or overlapping the centers of the ID's. Link to comment https://qualityforum.zeiss.com/topic/20952-combining-features-from-different-alignments/#findComment-119264 Share on other sites More sharing options...
[No...] Posted May 7, 2018 Share Posted May 7, 2018 Maybe the base alignment match (Resources > Utilities > Base Alignment Match) can do this.You would have to define a number of reference elements which must be measured manually at the 2nd ring so Calypso can shift the base alignment. But I've never actually used it. Only read about it in the help file. Link to comment https://qualityforum.zeiss.com/topic/20952-combining-features-from-different-alignments/#findComment-119266 Share on other sites More sharing options...
