need dual readout, dec deg and deg,min,sec
1. Set your default for the program to Degrees Minutes Seconds.
2. Create your characteristic for whatever angle you are reporting
FOR REPORTING DEGREES DECIMAL
3. create 'result element'
4. change calculation method to 'Number'
5. enter the following formula...
deg(angle(YOUR_ITEM_HERE))
YOUR_ITEM_HERE is whatever characteristic or feature attribute you select from your available list
