Fitting Position run collision
We have a probe collision, red light on Fitting Position run at 3rd angle position (A Axis: 180.000 & B Axis -92.500). The sphere is set at a 135° angle of inclination and a 315° angle of rotation.
Also I tried all different angles but the result was same. Is it possible something wrong with the fitting position path or what else could be the problem?
  • 1 month later...
It could possibly be the Shaft Radius setting for your Reference Sphere. The default is 6mm. If you open up Reference Sphere Management and increase this value the collision should go away.
