Min/Max of a Circle Question
What is the best way to get either the MIN (OR) Max of a circle, without getting/recording the other value? Is it possible using 2-Point Diameter? If it is, I am not seeing how to do it.
Basically,
In the feature, click the diameter tab to create a characteristic to report the diameter. Go to the dia characteristic and name it accordingly with MAX dia, copy/paste it and rename the 2nd characteristic as MIN, then open up each characteristic, select the dia and under evaluation settings in the filter (normally says LSQ), select the Min/Max evaluation of your choice (Inner Tangential, Outer Tangential, Max inscribed, Min Circumcised, etc..) and then open the other one and select it's evaluation. You then have only them two dia's reported.
