[Da...] Posted April 24, 2018 Share Posted April 24, 2018 What I'm looking to do is scan an ID, and then have Calypso output the average diameter (which it does by default), roundness, the maximum distance between two opposing points, and then the minimum distance between two opposing points. From what I understand, 2-point diameter does this, but I'm currently running an older version of Calypso which does not have this characteristic. We are currently running Calypso version 4.0.16. Is this possible, and if so, how? Link to comment Share on other sites More sharing options...
[Ca...] Posted April 24, 2018 Share Posted April 24, 2018 Could you accomplish this using Min Circumscribed and Max Inscribed evaluation elements? Link to comment Share on other sites More sharing options...
[Da...] Posted April 24, 2018 Author Share Posted April 24, 2018 Please sign in to view this quote. Actually ya, this should work. Our version still supports this. I guess I could recall the ID feature points for two additional features, and have different evaluation methods for each new one. Very messy, but works. Thanks. Link to comment Share on other sites More sharing options...
[Me...] Posted April 25, 2018 Share Posted April 25, 2018 You can just use one feature and change the evaluation methods on the separate characteristics. Link to comment Share on other sites More sharing options...
