selected feature extrapolated geometry
Dave,
There is no unwanted feature to delete. The unwanted planes are visual only (and disappear when a different feature is selected), not permanent fixtures.
Zach,
That is not what I want. That gets rid of highlighting the selected feature. I still want to highlight the selected feature. I just do not want it to create extra surfaces that are not there that visually get in the way of things behind it.
Attached is a picture with a different feature selected.
Also attached is a plan that I made with the type of selection that I want.
CAD Model Comparison will sometimes get rid of the phantom geometry. This can be found in CAD > CAD File > Cad Model Comparison. Click Comparison then highlight the feature(s) then Apply. This does not always work though.
Another area I have seen is in the CAD hierarchy there is an extra entity for the feature sitting all by itself. Deleting that will occasionally fix the problem.
At last resort I will extract the feature again, Paintbrush all the pertinent information and delete the old. Yeah it's a pain.
I have never heard of a good explanation as to the cause so I can't say where it is coming from, but on the other hand I haven't seen it in a while.
I did try all suggestions (I'm not about to ignore good-spirited advice), its just that none of them worked. I even saved the file as XXXtest and completely deleted everything (characteristics, features, and the CAD model itself). I loaded a CAD model into this now empty program, and got the same problem.
I then did the EXACT same thing with a brand new program, and did not have the problem.
I am almost certain that this is NOT phantom geometry that needs to be fixed. I believe that it is a setting in the program that somebody changed.
That "extra" geometry usually appears after a new (modified) CAD model has been loaded into an existing plan. When a new model is loaded (and the old one deleted), all features lose their bindings to the model faces (the information that enables Calypso to highlight them in pink). When Calypso is unable to find an associated CAD face for a feature, it displays that extra geometry for planes, cylinders and I think cones and spheres.
CAD model comparison can restore the model binding, but only if the nomials of the feature correspond with the size of the CAD face. For example, if a plane consists of more than one separate CAD faces, you select one of them to generate the feature, but put probing points on all of them. Then Calypso extends the nominal size of the plane to cover all points. This is when CAD comparison can fail because nominal and face are of different size.
If CAD comparison doesn't solve the problem, the alternative is what Zach suggested. You won't get back the pink highlighting that way, but at least you have free sight. If that method STILL doesn't work for you, I think you should post your plan here. Maybe it got corrupted in some way.
Guys, stop trying to 'fix' 'phantom geometry'.
The geometry is CORRECT. I just don't want to see it.
It is NOT something that needs to be deleted.
IT IS A SETTING THAT I SAW THE PREVIOUS GUY TURN ON AND OFF WITH THE CLICK OF A MOUSE.
I just don't know where that click is.
Norbert did a great job explaining why this happens and the solutions offered of cad comparison is the only thing that works BUT not all the time.
There is no magic switch to keep it from happening every time and the only choices you have is (1) cad comparison (2) toggling between the 3 buttons at the bottom that Michael mentioned but, you'll have to do every time if you want to see the feature without the phantom plane and (3) as you've already found out, create a whole new program.
*#@!! yep and $%*&#! again.
