[ZE...] Posted April 12, 2018 Share Posted April 12, 2018 I was wondering if it were possible to have a program automatically run a set number of times without any human interaction and provide one printout per run. Basically, I want to test a program to see how well it repeats, and I was thinking of automatically looping the program over and over again during a lunch break and looking at how much the dimensions are deviating per run. I would also like to add that we're currently using Calypso 4.0 (yes, really), so any possible solution must be applicable to an older version of the software. Thanks a bunch 🙂 David Chalmers | 03-04-2018 05:16 PM | Link to comment Share on other sites More sharing options...
[ZE...] Posted April 12, 2018 Author Share Posted April 12, 2018 Right click on an empty spot in the Characteristic tab. Select Loop then Insert and enter the number of times you want it to loop. Run the program and it will repeat the entered number of times with a printout for each run. Hope this helps. I'm running version 5. Mike Place | 03-05-2018 12:59 PM | Link to comment Share on other sites More sharing options...
[ZE...] Posted April 12, 2018 Author Share Posted April 12, 2018 Dear Mike, It's work, but my LOOP1 variable in feature formula won't change in each run. Is any setting need to change? LEE Michael | 04-12-2018 10:46 AM | Link to comment Share on other sites More sharing options...
