[Si...] Posted April 2, 2018 Share Posted April 2, 2018 Hi, I am looking for a way to add in a Signature Approval line to the Report. It would only be used for 1st Piece Items. What does the Textelement under Resources do? I have never used it. 2nd, The TEXT Bare on the report header, is there a way to add text or have text entered prior/after run? Or would that require another means after saving the report. Link to comment Share on other sites More sharing options...
[Mi...] Posted April 2, 2018 Share Posted April 2, 2018 Open the Editer. In the top "BOX" you could add PPAP Approval. Then in the bottom add a Approval Signature _____________ If you hit enter before the Approval, it will drop it down on the report so you have more room to sign. Also whatever you enter into the top area is what will show up on your report Link to comment Share on other sites More sharing options...
[Si...] Posted April 2, 2018 Author Share Posted April 2, 2018 Ok thanks. I will give this a try. Link to comment Share on other sites More sharing options...
[Si...] Posted April 2, 2018 Author Share Posted April 2, 2018 Hmm, So when I do Resource -> Textelement-> and do all of the changes I want, It does not show on the report. Is there a "switch" I must turn on ? lol Link to comment Share on other sites More sharing options...
[Mi...] Posted April 2, 2018 Share Posted April 2, 2018 You have to run the report. What you can do is run the program but UN CHECK clear results button and it should show up. Link to comment Share on other sites More sharing options...
[Si...] Posted April 2, 2018 Author Share Posted April 2, 2018 Yup, That is what I do. It just does not show on report.Text ele.png Link to comment Share on other sites More sharing options...
[Mi...] Posted April 2, 2018 Share Posted April 2, 2018 I have no idea why its not showing up on your reports. I have done it this way numerous times and never had an issue. Are you using the Custom Report or are you using PiWeb reporting? If you are using PiWeb this is probably not going to work. Have not dealt with PiWeb much as of late. Link to comment Share on other sites More sharing options...
[Si...] Posted April 2, 2018 Author Share Posted April 2, 2018 piWeb Reporting, Standard Protocol.Reporting.png Link to comment Share on other sites More sharing options...
[Mi...] Posted April 2, 2018 Share Posted April 2, 2018 Yeah with PiWeb im not sure how to make this happen. I know there is a way 🙁 Link to comment Share on other sites More sharing options...
[Si...] Posted April 2, 2018 Author Share Posted April 2, 2018 What do you use? I can make a custom report then. Link to comment Share on other sites More sharing options...
[Si...] Posted April 2, 2018 Author Share Posted April 2, 2018 What do you use, I can make a custom report then. Link to comment Share on other sites More sharing options...
[Mi...] Posted April 2, 2018 Share Posted April 2, 2018 I'm still using the Custom Reporting. That is until Zeiss goes to PiWeb 100%. Link to comment Share on other sites More sharing options...
[Si...] Posted April 2, 2018 Author Share Posted April 2, 2018 Ya, I just added a custom to the reporting and the text element works. So now it just shoots out two reports when I need it to. Hopefully there is a way in piWeb to activate it. Link to comment Share on other sites More sharing options...
[Mi...] Posted April 2, 2018 Share Posted April 2, 2018 You can stop the PiWeb report by clicking the small monitor Icon as in my screen shot. If you don't want both reports anyway Link to comment Share on other sites More sharing options...
[Si...] Posted April 2, 2018 Author Share Posted April 2, 2018 Oh ya, forgot about the little things. Thanks. Link to comment Share on other sites More sharing options...
[Mi...] Posted April 2, 2018 Share Posted April 2, 2018 Don't we all Link to comment Share on other sites More sharing options...
[Kn...] Posted April 5, 2018 Share Posted April 5, 2018 Hey together, the Textelement do not work in PiWeb. Therefor you can use the group. Take the elements into a group and in the groupcomment you can write your text. This text will appear on the PiWeb printout. Link to comment Share on other sites More sharing options...
[e1...] Posted April 5, 2018 Share Posted April 5, 2018 Why couldn't you just add a space for a signature to the header or footer of your PiWeb report?signature.JPG Link to comment Share on other sites More sharing options...
[Ch...] Posted April 6, 2018 Share Posted April 6, 2018 Go to your multiple printout tab and make sure "Text Features" is selected. Link to comment Share on other sites More sharing options...
