[ZE...] Posted April 3, 2018 Share Posted April 3, 2018 How compatible is PiWeb with PCM? I collect info (pallet position, names, impression numbers... the list goes on) in both pre and post PCM code. The variables are sent to a custom report template. Will PiWeb accept variables? Randy Hnatkowicz | 04-02-2018 02:26 PM | Link to comment https://qualityforum.zeiss.com/topic/21112-piweb-and-pcm/ Share on other sites More sharing options...
[ZE...] Posted April 3, 2018 Author Share Posted April 3, 2018 Are the variables defined in the userfields.ini? If so, PiWeb can import all of them. Laura Jaschke1 | 04-02-2018 02:58 PM | Link to comment https://qualityforum.zeiss.com/topic/21112-piweb-and-pcm/#findComment-120392 Share on other sites More sharing options...
[ZE...] Posted April 3, 2018 Author Share Posted April 3, 2018 Indeed, they are. Question answered! +1 Laura Randy Hnatkowicz | 04-02-2018 05:21 PM | Link to comment https://qualityforum.zeiss.com/topic/21112-piweb-and-pcm/#findComment-120394 Share on other sites More sharing options...
[cd...] Posted April 5, 2018 Share Posted April 5, 2018 Did you figure out how to get them in your report? I can help you set it up if need be. Link to comment https://qualityforum.zeiss.com/topic/21112-piweb-and-pcm/#findComment-120396 Share on other sites More sharing options...
