Probe Qualification woes...
Hi all,
I seem to be having an issue that I can't quite replicate all of the time.
We have multiple DuraMax machines on the shop-floor and they all have the same configuration and setup (minus some probe systems being different).
On every CMM that we own, I always create a Probe Calibration program for the operators to run at the start of their shift. As far as I am aware, all of the Probe Calibration programs are the same (except if one machine has more probe systems than the other).
On one particular machine the operator is complaining that they some times have to run the program 4 times, other wise they will get a "Current Stylus Not Qualified" error even though the machine perfectly calibrated (as far as I can tell).
I'm not really able to replicate it myself, and I know for sure that if I manually qualify it (either a new touch-off, or using the caliper) that I've never had this issue.
I'm incline to think that it is operator issue, but I'm being pressured to figure it out, so I'm reaching out to everyone to see if they've seen this before and what they did to fix it.
Any and all help is greatly appreciated. Thanks.
Richard Shomaker | 03-27-2018 03:19 PM |
https://qualityforum.zeiss.com/topic/21128-probe-qualification-woes/
If you use new Calypso revision which is using ID chip data then it is possible that XXT adapter plate is dirty and head cant read ID data. Finally adapter plate ID is unknown for Calypso and therefore not qualified. First try to clean plates and head contact plate with alcohol (with CMM switched off 😉 ). If this not help -take a close look at magnet in center of adapter plate and ring around this magnet. In this place you can sometimes find micro sized pieces of metal which can make troubles. Same problem may be in center of XXT head.
Marcin Mieszala | 03-27-2018 04:12 PM |
