Export Points
How do i use the "exportPoints(Feature name,file name)" PCM command?
I need the "Syntax" for this.
Is this the same feature as if i were to right click on a feature and select Export Points?
See attached.
You can also go into the features settings editor an activate export points on the desired features.
The format of the exported points can be set in Results to File
Hi,
I have tried this but can only Export Point manually.
i have gone through the Settings for cnc run bu the Points dont seem to save.
any tips?
Today, I noticed that I wasn't able to produce exported points after several runs. Then, I did something (emphasis on "something") and it started working all of a sudden. Don't ask me what the "something" was.
