Stylus System Creator (SSC) probes disappear after a while in Planner
I have been noticing that probes created in SSC, particularly custom probes, disappear.
Typically, its disk probes and "L" angled probes.
Just poof, no more probe.
If I am using the VAST XTR sensor, I have to recreate every stylus/articulation by hand, if I am using the RDS XXT sensor, you go through a bunch of steps that may or may not recall all of your articulations.
Has anyone else had or have this issue?
If yes, have you been able to resolve it?
Do  you have a fixed place where your SSC source files are stored or do you delete some/all of them after importing into Calypso?
I'm asking because I never found out where Calypso stores the imported SSC probes. There is a SCC folder somewhere, but it doesn't contain all of the probes. So I suspect maybe there is no seperate storage, but it might simply take them from the original import directory. And if you delete something from it......
This is just speculation. I never took the time to analyze that in-depth.
Edited
I have found, so it seems, that the imported SSC file is stored in the same location as the imported SSC file.
The name is changed, it has a series of numbers appended to the original name.
Example:
"#7 Rot.ssc" becomes "#7 Rot_515273413.ssc".
It's my best guess.
