[Ha...] Posted November 16, 2024 Share Posted November 16, 2024 I have a code here that automatically exports reports, but when encountering multiple alignment methods in the measurement program, the exported report will have an error message on the report page for one alignment method. Is there any way to solve this problem? I will share the code below -*- coding: utf-8 -*- import gom import os RESULT=gom.script.sys.execute_user_defined_dialog (content='<dialog>' \ ' <title>Export PDF</title>' \ ' <style></style>' \ ' <control id="OkCancel"/>' \ ' <position></position>' \ ' <embedding></embedding>' \ ' <sizemode></sizemode>' \ ' <size width="414" height="133"/>' \ ' <content columns="2" rows="1">' \ ' <widget type="label" column="0" row="0" columnspan="1" rowspan="1">' \ ' <name>label</name>' \ ' <tooltip></tooltip>' \ ' <text>Savepath:</text>' \ ' <word_wrap>false</word_wrap>' \ ' </widget>' \ ' <widget type="input::file" column="1" row="0" columnspan="1" rowspan="1">' \ ' <name>file_report</name>' \ ' <tooltip></tooltip>' \ ' <type>directory</type>' \ ' <title>Choose File</title>' \ ' <default></default>' \ ' <limited>false</limited>' \ ' <file_types/>' \ ' <file_types_default></file_types_default>' \ ' </widget>' \ ' </content>' \ '</dialog>') path = RESULT.file_report stages = gom.app.project.stages gom.script.report.update_report_page( pages=gom.app.project.reports, used_alignments='report', used_digits='report', used_legends='report', used_stages='current', used_units='report') reportpages = gom.app.project.reports for j in range(len(stages)): gom.script.sys.show_stage (stage = stages[j]) name = str(stages[j].name) savepath = os.path.join(path, name) gom.script.report.update_report_page ( pages=reportpages, used_alignments='report', used_digits='report', used_legends='report', used_stages='current', used_units='report') gom.script.report.export_pdf ( export_all_reports=True, file=str(savepath) + '.pdf', jpeg_quality_in_percent=90, max_dpi=150) Link to comment Share on other sites More sharing options...
