Video quality
greetings
is there any way to improve video quality when exporting just video?
I have the video resolution set to very high
Format: standard mp4 mpeg-4 part 10 H.264
but the video quality is poor.
Thanks for any help.
In Zeiss Volume Inspect X-ray you can export video in report or just video. You just need to make line (or any other geometry) inside or outside of your object, than you can make an animation following the line. After that you can see the animation of your object or on the cut through the object following the line. Then you can do the report page vith that animation as a video. If you want, you can export the report page as the video or the video only with the preferred setting of quality. I am not sure if there are any other options to improve the final quality  of the exported video. It is true, that the video quality is a bit worse when you export it, than the animation in the program itself.
