Is there a way to calculate and generate a report without finishing the run?
Lets say a program is running and the CMM alarms out. Is there an easy way to calculate the characteristics and generate report even though the program is unfinished?
There are operators who have very limited CMM knowledge and sometimes they need to do this when I am not around to mask/mini plan or adjust the program.
Any suggestions?
Both are good suggestions
I think subsequent evaluation is a little more in depth then we are wanting to get. That could get messy with the data management.
Looking at individual characteristics is an option although Ideally they would be able to generate a report to interpret or send out.
In my mind it would be a check box similar to "clear existing results" where the user can hit run and it will calculate whatever the program has ran so far
