Formula to use an individual point from a curve for a dimension?
We use trigger points for our curves instead of scanning, would like to use certain points in the curve to measure to other features or datum's. So if I have 50 points I want point 20 actual location in Z to measure to a plane not associated with the curve alignment.
I know with patterns you can pick an individual point or feature [ex. Point Top (*) where if I want the second point of the pattern I would enter Point Top(2) instead of the asterisk ]
I know this is not a formula but you can create a point feature, select recall feature points, then right-click on the curve and select Add Range Limits.   Click the Point button and enter the point number.
  • 3 months later...
