changing order in protocol header
Hello Community,
i want to change the order of the columns in the header, we dont use de new pi web and multiple protocol function.
can somebody help me out? 🙂
Greetings
Daniel
I don't think that order can be changed.
If you are using old protocol, then any requested field have to be present on protocol header, otherwise you won't be able to fill it.
I found a file ( "C:\Users\Public\Documents\Zeiss\Calypso x.x\protocol\protform\systemfieldsassistance.ini" ) - not sure if it's present on your system.
There you can try to sort content ( possibly only bottom part "[Fieldnames]", where are all fields written ) and do restart of Calypso after change.
