[Ri...] Posted December 4, 2024 Share Posted December 4, 2024 (edited) We are licensed for step files, in and out. Every time I save the model as a step file, dialog boxes appear to be making a file, but no file is created. I can save as SAB, SAT, STL and VRML without problems. These step files acting like step children: You're not my daddy. I don't have to do what you want. 😂 Edited December 4, 2024 Link to comment https://qualityforum.zeiss.com/topic/21412-calypso-v2022-will-not-save-cad-model-as-a-step-file/ Share on other sites More sharing options...
[Cl...] Posted December 4, 2024 Share Posted December 4, 2024 (edited) Are you importing the model as a .stp? I've had issues in the past if I didn't change the file extension from .step to .stp Edited December 4, 2024 Link to comment https://qualityforum.zeiss.com/topic/21412-calypso-v2022-will-not-save-cad-model-as-a-step-file/#findComment-122152 Share on other sites More sharing options...
[Ri...] Posted December 4, 2024 Author Share Posted December 4, 2024 (edited) Calypso defaults to stp, and I have change the suffix from step to stp before without problems. I used the same file on Calypso v2017 and it saves a stp file no problem. Edited December 4, 2024 typo Link to comment https://qualityforum.zeiss.com/topic/21412-calypso-v2022-will-not-save-cad-model-as-a-step-file/#findComment-122154 Share on other sites More sharing options...
[Ro...] Posted December 4, 2024 Share Posted December 4, 2024 I have had this issue too. I ended up using a different Calypso revision to get my model to save. I think a patch update borked this, because it use to work in 2022 just fine. Link to comment https://qualityforum.zeiss.com/topic/21412-calypso-v2022-will-not-save-cad-model-as-a-step-file/#findComment-122158 Share on other sites More sharing options...
[Ri...] Posted December 4, 2024 Author Share Posted December 4, 2024 (edited) Please sign in to view this quote. I'm guessing the same thing about a patch/update. This worked fine until the last patch/update. Edited December 4, 2024 Link to comment https://qualityforum.zeiss.com/topic/21412-calypso-v2022-will-not-save-cad-model-as-a-step-file/#findComment-122160 Share on other sites More sharing options...
[Ri...] Posted January 16, 2025 Author Share Posted January 16, 2025 Is there a fix for this from Zeiss? If I make changes, I can't save the file unless I save as a SAT or SAB and those wont load in older versions. 🤨 Link to comment https://qualityforum.zeiss.com/topic/21412-calypso-v2022-will-not-save-cad-model-as-a-step-file/#findComment-124498 Share on other sites More sharing options...
[na...] Posted January 17, 2025 Share Posted January 17, 2025 Please sign in to view this quote. Check the dropdown when saving, is there a Sat 19 option? This is older ACIS kernel and should work with older Calypso versions. Link to comment https://qualityforum.zeiss.com/topic/21412-calypso-v2022-will-not-save-cad-model-as-a-step-file/#findComment-124534 Share on other sites More sharing options...
[Ma...] Posted January 17, 2025 Share Posted January 17, 2025 Unfortunately "save as .stp file" has a BUG in the latest CALYPSO 2022 which wont be fixed since its out of support by Developement. Link to comment https://qualityforum.zeiss.com/topic/21412-calypso-v2022-will-not-save-cad-model-as-a-step-file/#findComment-124536 Share on other sites More sharing options...
[Ri...] Posted January 17, 2025 Author Share Posted January 17, 2025 Please sign in to view this quote. I will check this out. 😉 Link to comment https://qualityforum.zeiss.com/topic/21412-calypso-v2022-will-not-save-cad-model-as-a-step-file/#findComment-124548 Share on other sites More sharing options...
[Mi...] Posted January 20, 2025 Share Posted January 20, 2025 Please sign in to view this quote. This is so helpful to know for anybody who might find this thread from google someday. It's obvious after being told to look for it, but if you don't think to look you wouldn't even realize it's an option to save in an older version. Link to comment https://qualityforum.zeiss.com/topic/21412-calypso-v2022-will-not-save-cad-model-as-a-step-file/#findComment-124630 Share on other sites More sharing options...
[Ri...] Posted January 21, 2025 Author Share Posted January 21, 2025 Please sign in to view this quote. Please sign in to view this quote. I am able to save as a SAT 19 version, with this I can use it v2017 and SolidWorks. Thanks. Link to comment https://qualityforum.zeiss.com/topic/21412-calypso-v2022-will-not-save-cad-model-as-a-step-file/#findComment-124678 Share on other sites More sharing options...
[na...] Posted January 21, 2025 Share Posted January 21, 2025 Please sign in to view this quote. I'm glad it works. Link to comment https://qualityforum.zeiss.com/topic/21412-calypso-v2022-will-not-save-cad-model-as-a-step-file/#findComment-124690 Share on other sites More sharing options...
