Intersection of Torus to Torus and Torus to conical surfaces
Does anyone have a solution to measuring depths and diameters from where two Toruses (Tori?)  intersect?  I'm trying to eliminate having to use a mold for these features. I have tried intersecting two subsidiary radii on each feature patterned rotationally at 30-degree intervals. Used those intersections to generate a circle and report that diameter and length.  I'm just not sure this is the most efficient and accurate way to capture these features. I'm doing the same with lines on Cones to Torus intersections as well. I feel like I have to be missing an easier way. Thanks in advance for any suggestions you fine people may have.
Edited
